Sony VAIO PCG-933A RAM Replacement
  1. Sony VAIO PCG-933A RAM Replacement, Battery: step 1, image 1 of 2 Sony VAIO PCG-933A RAM Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A RAM Replacement: step 2, image 1 of 3 Sony VAIO PCG-933A RAM Replacement: step 2, image 2 of 3 Sony VAIO PCG-933A RAM Replacement: step 2, image 3 of 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A RAM Replacement, RAM: step 3, image 1 of 1
    • With the laptop facing you, flip the laptop upside down.
  4. Sony VAIO PCG-933A RAM Replacement: step 4, image 1 of 3 Sony VAIO PCG-933A RAM Replacement: step 4, image 2 of 3 Sony VAIO PCG-933A RAM Replacement: step 4, image 3 of 3
    • Remove the 4mm Phillips screw that holds the small panel in the center of the laptop in place.
    • Then remove the panel covering the RAM.
    • The RAM should now be visible.
  5. Sony VAIO PCG-933A RAM Replacement: step 5, image 1 of 3 Sony VAIO PCG-933A RAM Replacement: step 5, image 2 of 3 Sony VAIO PCG-933A RAM Replacement: step 5, image 3 of 3
    • Release the plastic switches on each side of the stick of RAM.
    • Carefully slide the stick of RAM out at an angle.
    • DO NOT FORCE OUT.
Sara Lillard
165 Reputation
8 Guides authored
Cal Poly, Team 12-36, Maness Spring 2011 Member of Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 1,933
