Introduction
If you have a problem with starting-up the OS, or if you want to erase all data, or you forgot your password, PIN, pattern code you can do a Factory reset.
Attention!!! This will erase all your data!!! It's good to do BACKUP first.
Video Overview
Metod 1:
- Settings
- Backup & reset
- Factory data reset
The tablet will restart automatically.
!!! From the "Backup & reset" menu you can do Back up my data !!!
Metod 2:
Power of the tablet. Pres and hold the Power On key and the Volume Up key at the same time.
When you see the Sony logo release the Power On button but continue to press the Volume Up button.
Now you are in the Android recovery menu. Use Volume keys to scroll and the Power On key to select. From the options select:
- Reset to Factory Settings
- Yes - erase all user data
- The tablet will restart alone
19 other people completed this guide.
23 Comments
Hallo , I follow the steps , nothing is happening . Exists a different way ? dedudan@yahoo.com
hi man
i do but its very VERY specific
press power
when te white led upper power flash on quiqkly relase power and press vol up..........
when the display make a very litle flash relase the vol buton
ENJOY AND GIVE THANKS
Hi, you are my knight in shining armour. You were right, it´s incredibly specific. You have to watch the white light above the power button and be plugged in into a socket. Nobody else mentioned the little white light, I was close to believe my tablet was defect.
Thank you very, very much.
ive tried it many times but still is stuck on sony logo
read my before coment
enjoy
Thanks!!!! It worked. For guys who dont know, you should pług your tan to the electricity. Then everything works fine
Yes. I had to try it about 10 times before it entered the "Rescue Mode". Don't opt for the rescue mode. You don't care about saving anything at this point. Press-"Skip". And it will go to full restore. Be patient. But the split second of both bottoms was hard.
Please see above comment.
It is similar to the hard reset of vaio laptops. That is, turning on and immediately pressing F-10 rapidly. It enters hard restore mode. But the tablet uses the pwr and + volume buttons together. Keep trying. My tablet works Fine now.
Make sure you're connected to power.
I know this is a long time ago, however just tried to start my xperia tablet as thought it was dead. Power and volume up button at same time ( charging led flashes twice) then I press power again and the white led lights up for about 1-2 seconds, I then press the up volume but no matter how long I hold the button down for there is nothing from the screen. Even if I keep pressing volume up button whilst pressing power again to get the white led, nothing happens.
This doesnt work
Hello!!!! Thanks for your help, excellente procedure, easy if you follow carefully the steps =)
After I reset my sony tab it still will not boot up it won't go passed the sony please help
thank you ‘tunerlezoart4everx’ its specific and working :)
hi man
press power
tunerlezoart4everx - 11-09-2015
