Sony SRS-XG300 Tweeter Replacement
    1. Sony SRS-XG300 Tweeter Replacement, Fabric Cover: step 1, image 1 of 3 Sony SRS-XG300 Tweeter Replacement, Fabric Cover: step 1, image 2 of 3 Sony SRS-XG300 Tweeter Replacement, Fabric Cover: step 1, image 3 of 3
      • Before beginning, make sure to unplug and power off your speaker.
      • With the Sony label on the left, roll the speaker horizontally to the bottom of the speaker with the rubber stands.
      • Remove four 12 mm screws with a Phillips #1 screwdriver.
      • Remove the loose rubber feet.
      Ask FixBot
    2. Sony SRS-XG300 Tweeter Replacement: step 2, image 1 of 2 Sony SRS-XG300 Tweeter Replacement: step 2, image 2 of 2
      • Insert the metal spudger tool at 90-degree angle into the right part of seam.
      • Pry off the top part of the fabric cover using the metal spudger.
      • Follow the seam to completely detach the top part of the fabric cover.
      • Repeat to remove the bottom part of the fabric cover.
      Ask FixBot
    1. Sony SRS-XG300 Tweeter Replacement, Tweeter: step 3, image 1 of 1
      • Unclip all six trapezoid-shaped notches around the rim of the speaker using the metal spudger.
      • Begin at the end of the speaker volume button board for an easier process.
      • You may have to work clips off, pushing away from the speaker simultaneously.
      • Remove the speaker mounting ring.
      • Repeat the same steps on the other end of the speaker with the power button board.
      Ask FixBot
    2. Sony SRS-XG300 Tweeter Replacement: step 4, image 1 of 3 Sony SRS-XG300 Tweeter Replacement: step 4, image 2 of 3 Sony SRS-XG300 Tweeter Replacement: step 4, image 3 of 3
      • Remove the four 12 mm screws on the corners of each tweeter using the Phillips #1 screwdriver.
      • The tweeters are smaller compared to the two woofers in the center of the speaker.
      Ask FixBot
    3. Sony SRS-XG300 Tweeter Replacement: step 5, image 1 of 2 Sony SRS-XG300 Tweeter Replacement: step 5, image 2 of 2
      • Lift the right tweeter up to expose the connected cables at the top and bottom of the right tweeter.
      • Pinch down on the metal tab and pull outward to disconnect each cable.
      • Pieces are malleable, so you may have to maneuver to disconnect.
      • Lift the right tweeter up and out of the case.
      Ask FixBot
    4. Sony SRS-XG300 Tweeter Replacement: step 6, image 1 of 3 Sony SRS-XG300 Tweeter Replacement: step 6, image 2 of 3 Sony SRS-XG300 Tweeter Replacement: step 6, image 3 of 3
      • Remove the six 12 mm screws on the rim of the radiator using the Phillips #1 screwdriver.
      • Uncap the left bass radiator. Detach the blue ribbon cable from the bass radiator.
      • Using the angled tweezers will make this process easier.
      • Remove the left bass radiator.
      Ask FixBot
    5. Sony SRS-XG300 Tweeter Replacement: step 7, image 1 of 2 Sony SRS-XG300 Tweeter Replacement: step 7, image 2 of 2
      • Disconnect the microphone by pulling on the white end of the microphone cable.
      Ask FixBot
    6. Sony SRS-XG300 Tweeter Replacement: step 8, image 1 of 2 Sony SRS-XG300 Tweeter Replacement: step 8, image 2 of 2
      • Lift the left tweeter up to expose the connected cables at the top and bottom of the left tweeter.
      • Lift the left tweeter up and out of the case.
      Ask FixBot
Melody
490 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 51
All Time: 400
