Sony SRS-XG300 Power Button Replacement
  1. Sony SRS-XG300 Power Button Replacement, Fabric Cover: step 1, image 1 of 3 Sony SRS-XG300 Power Button Replacement, Fabric Cover: step 1, image 2 of 3 Sony SRS-XG300 Power Button Replacement, Fabric Cover: step 1, image 3 of 3
    • Before beginning, make sure to unplug and power off your speaker.
    • With the Sony label on the left, roll the speaker horizontally to the bottom of the speaker with the rubber stands.
    • Remove four 12 mm screws with a Phillips #1 screwdriver.
    • Remove the loose rubber feet.
    Ask FixBot
  2. Sony SRS-XG300 Power Button Replacement: step 2, image 1 of 2 Sony SRS-XG300 Power Button Replacement: step 2, image 2 of 2
    • Insert the metal spudger tool at 90-degree angle into the right part of seam.
    • Pry off the top part of the fabric cover using the metal spudger.
    • Follow the seam to completely detach the top part of the fabric cover.
    • Repeat to remove the bottom part of the fabric cover.
    Ask FixBot
  3. Sony SRS-XG300 Power Button Replacement, Power Button: step 3, image 1 of 2 Sony SRS-XG300 Power Button Replacement, Power Button: step 3, image 2 of 2
    • Remove the four 12 mm screws on the corners of the left tweeter using the Phillips #1 screwdriver.
    Ask FixBot
  4. Sony SRS-XG300 Power Button Replacement: step 4, image 1 of 3 Sony SRS-XG300 Power Button Replacement: step 4, image 2 of 3 Sony SRS-XG300 Power Button Replacement: step 4, image 3 of 3
    • Use the metal spudger to peel off the adhesive button on the power switch (power, bluetooth, and megabass) to access the control panel underneath.
    Ask FixBot
  5. Sony SRS-XG300 Power Button Replacement: step 5, image 1 of 2 Sony SRS-XG300 Power Button Replacement: step 5, image 2 of 2
    • Unscrew the one 7.5 mm in the middle of the control panel with a Phillips #1 screwdriver.
    Ask FixBot
  6. Sony SRS-XG300 Power Button Replacement: step 6, image 1 of 3 Sony SRS-XG300 Power Button Replacement: step 6, image 2 of 3 Sony SRS-XG300 Power Button Replacement: step 6, image 3 of 3
    • Carefully lift up the control panel.
    • You may need to use the metal spudger to make this step easier.
    • Do this slowly and do not lift it all the way up, as it can tear the cables.
    • Detach the blue ribbon cable from the power button.
    • If not visible, lift the left tweeter to see a better view of the cable internally.
    • Remove the power button from the speaker.
    Ask FixBot
Melody
475 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 215
