Introduction
If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Remove the two Phillips screws from the I/O board.
Remove the front panel to the speaker by pushing on the two tabs in the corners.
Disconnect the ribbon cable from the I/O board.
Carefully remove the I/O board from the speaker.
Is the I/0 board available, mine is damaged and the took it to repair shop but they are saying it cant be repaired
Geez, they make it a 'challenge' to get those gaskets under the batt covers off.
Don't make ant immediate plans....call your wife, you're gonna be a little late.
Jim Malina - Reply
I need battery with board please help ??
Kevin Ke - Reply
