Sony Pulse Elite Edition Headband Replacement
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: step 1, image 1 of 2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: step 1, image 2 of 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: step 2, image 1 of 2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: step 2, image 2 of 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: step 3, image 1 of 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: step 3, image 2 of 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: step 3, image 3 of 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: step 4, image 1 of 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
    bro how can i buy pulse 3d headband?
    vahid najafi - Reply
3 other people completed this guide.
Chris Echter
865 Reputation
4 Guides authored
Clemson, Team 14-2, Shirley Spring 2015 Member of Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Members
12 Guides authored
One Comment
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 85
All Time: 5,840
