Sony Pulse Elite Edition Battery Replacement
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: step 1, image 1 of 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: step 2, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: step 2, image 2 of 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: step 3, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: step 3, image 2 of 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: step 4, image 1 of 1
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: step 5, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: step 5, image 2 of 2
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
Chris Echter
865 Reputation
4 Guides authored
Clemson, Team 14-2, Shirley Spring 2015 Member of Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 Members
12 Guides authored
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 54
All Time: 10,562
