Sony PRS-505 SD Card Reader Replacement
    1. Sony PRS-505 SD Card Reader Replacement, SD Card: step 1, image 1 of 2 Sony PRS-505 SD Card Reader Replacement, SD Card: step 1, image 2 of 2
      • Press the SD card inward until it clicks and springs outward.
      • Take the SD card out of the device.
      Ask FixBot
    1. Sony PRS-505 SD Card Reader Replacement, Battery: step 2, image 1 of 2 Sony PRS-505 SD Card Reader Replacement, Battery: step 2, image 2 of 2
      • Remove the stylus.
      • Remove the four 2 mm screws from the back of the device using a Phillips #000 screwdriver.
      • Loosen the screw on the bottom of the device that is in its own little divot using a Phillips #000 screwdriver.
      Ask FixBot
    2. Sony PRS-505 SD Card Reader Replacement: step 3, image 1 of 2 Sony PRS-505 SD Card Reader Replacement: step 3, image 2 of 2
      • Remove the thin panel on the bottom of the device using an opening tool.
      • Use a Phillips #000 screwdriver to remove the three 5 mm screws that are underneath the panel.
      Ask FixBot
    3. Sony PRS-505 SD Card Reader Replacement: step 4, image 1 of 2 Sony PRS-505 SD Card Reader Replacement: step 4, image 2 of 2
      • Remove the thin top panel using an opening tool.
      • Remove the two metal brackets from the top of the device.
      • They are both silver with a hole.
      Ask FixBot
    4. Sony PRS-505 SD Card Reader Replacement: step 5, image 1 of 1
      • Gently but firmly push the inner components of the PRS out towards the top until the ribbon cable is completely exposed and accessible.
      Ask FixBot
    5. Sony PRS-505 SD Card Reader Replacement: step 6, image 1 of 1
      • Disconnect the ribbon cable.
      • Carefully continue to push the inner body of the device towards the top until the battery is accessible.
      Ask FixBot
    6. Sony PRS-505 SD Card Reader Replacement: step 7, image 1 of 3 Sony PRS-505 SD Card Reader Replacement: step 7, image 2 of 3 Sony PRS-505 SD Card Reader Replacement: step 7, image 3 of 3
      • Gently pry the battery from its placeholder within the device’s inner body. Disconnect and remove the battery.
      • If the battery won’t come out, remove the entire compartment by removing the two 3 mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    1. Sony PRS-505 SD Card Reader Replacement, SD Card Reader: step 8, image 1 of 3 Sony PRS-505 SD Card Reader Replacement, SD Card Reader: step 8, image 2 of 3 Sony PRS-505 SD Card Reader Replacement, SD Card Reader: step 8, image 3 of 3
      • Disconnect the two ribbon cables: one next to the battery compartment and the other next to the SD card reader.
      • Remove the black midframe.
      Ask FixBot
    2. Sony PRS-505 SD Card Reader Replacement: step 9, image 1 of 1
      • Remove the single 2.5 mm screw using a Phillips #00 screwdriver.
      Ask FixBot
    3. Sony PRS-505 SD Card Reader Replacement: step 10, image 1 of 1
      • Use a soldering iron to desolder the SD card reader from its connecting points on the ribbon colored compartment.
      • Remove the SD card reader.
      • Before you start reassembling, you will have to resolder your new reader onto the ribbon colored compartment.
      Ask FixBot
DaJean
660 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 61
All Time: 208
