Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓Even with the Sony PRS-505 being important piece of e-reader history, devices eventually face the end of their battery life.
This guide will show you how to safely get to and replace the battery in the particular device so that you can get back to doing your thing.
Warning: The ribbon cables are very delicate. The clips and screws also securing the enclosure require extra care to prevent breaking. proceed slowly and with patience
Tools
Press the SD card inward until it clicks and springs outward.
Take the SD card out of the device.
Remove the stylus.
Remove the four 2 mm screws from the back of the device using a Phillips #000 screwdriver.
Loosen the screw on the bottom of the device that is in its own little divot using a Phillips #000 screwdriver.
