Sony NEX-7 LCD Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Sony NEX-7 LCD Assembly Replacement, LCD Assembly: step 1, image 1 of 1
      • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
      Ask FixBot
    2. Sony NEX-7 LCD Assembly Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
      • The 5/32" upper screw
      • The 3/32" lower screw
      Ask FixBot
    3. Sony NEX-7 LCD Assembly Replacement: step 3, image 1 of 1
      • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    4. Sony NEX-7 LCD Assembly Replacement: step 4, image 1 of 1
      • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 LCD Assembly Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
      Ask FixBot
    6. Sony NEX-7 LCD Assembly Replacement: step 6, image 1 of 1
      • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
      Ask FixBot
    7. Sony NEX-7 LCD Assembly Replacement: step 7, image 1 of 2 Sony NEX-7 LCD Assembly Replacement: step 7, image 2 of 2
      • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
      • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
      • Pull on the D rings on either side of the camera to start removing the assembly.
      • Once the brackets are cleared from black shell, take them off and set them aside.
      • Continue to remove the screen assembly.
      Ask FixBot
    8. Sony NEX-7 LCD Assembly Replacement: step 8, image 1 of 1
      • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
      • Unplug the cable by applying tweezers to the tabs on either side of the plug.
      • Set the LCD assembly aside.
      Ask FixBot
Jay Miley
5,476 Reputation
13 Guides authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
168 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 396
