Sony MVC-FD200 LCD Display Screen Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
16
Past 30 Days:
65
All Time:
703
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide will walk you through the steps needed to safely replace the damaged LCD screen, ensuring that your camera looks and works as good as new. Whether you're a DIY enthusiast or just looking to save on repair costs, this step-by-step tutorial will help you complete the replacement process with minimal tools and effort. Let's get started on bringing your Sony MVC-FD200 back to life!
Tools
    1. Sony MVC-FD200 LCD Display Screen Replacement, Battery: step 1, image 1 of 1
      • Using your finger, slide the tab on the battery door up to release the battery latch.
      Ask FixBot
    2. Sony MVC-FD200 LCD Display Screen Replacement: step 2, image 1 of 1
      • Lift the battery door to reveal the battery compartment.
      • Push the gray lever to the left side to remove the battery.
      • If any other repairs are needed, make sure to carefully remove the battery to avoid any electric shock or short circuits during repairs.
      Ask FixBot
    1. Sony MVC-FD200 LCD Display Screen Replacement, Back Cover: step 3, image 1 of 1
      • Turn the camera so that the top is facing down towards the table.
      • Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
      Ask FixBot
    2. Sony MVC-FD200 LCD Display Screen Replacement: step 4, image 1 of 2 Sony MVC-FD200 LCD Display Screen Replacement: step 4, image 2 of 2
      • Flip the camera on both sides and remove the rest of the screws with arrows facing towards them.
      • Remove the 2.0 mm screws with the Phillips #00 screwdriver for both sides of the camera.
      Ask FixBot
    1. Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: step 5, image 1 of 3 Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: step 5, image 2 of 3 Sony MVC-FD200 LCD Display Screen Replacement, LCD Display Screen: step 5, image 3 of 3
      • Detach the ribbon cable that connects the two halves of the device to split them apart.
      • Gently pry up the black plastic tab to slide out the ribbon cables.
      • Be gentle because this component is thin, but do not be afraid to damage the ribbon cable during removal. Add force progressively in small amounts.
      Ask FixBot
    2. Sony MVC-FD200 LCD Display Screen Replacement: step 6, image 1 of 1
      • Remove the six 2.0 mm screws which hold the motherboard in place using the Phillips #00 screwdriver.
      Ask FixBot
    3. Sony MVC-FD200 LCD Display Screen Replacement: step 7, image 1 of 1
      • Remove the four 2.0 mm screws which hold down the heat shield using the Phillips #00 screwdriver.
      Ask FixBot
    4. Sony MVC-FD200 LCD Display Screen Replacement: step 8, image 1 of 2 Sony MVC-FD200 LCD Display Screen Replacement: step 8, image 2 of 2
      • The LCD display and the backlight which sits on top of it are displayed.
      • Push both components out.
      Ask FixBot
Nathan Cordeiro
114 Reputation
1 Guide authored
1 Guide Comment
I have a Mavica FD71, will this work about the same? (Pixels in the middle of the screen have started to die) I’ve been looking, but I can’t find a replacement lcd panel for my model, do the Mavica FD2000 and the FD71 use the same lcd panel?
Average AirPod User - Reply Share
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 65
All Time: 703
