Sony KDF-E60A20 Lamp Replacement
  1. Sony KDF-E60A20 Lamp Replacement, Lamp: step 1, image 1 of 3 Sony KDF-E60A20 Lamp Replacement, Lamp: step 1, image 2 of 3 Sony KDF-E60A20 Lamp Replacement, Lamp: step 1, image 3 of 3
    • Remove the two thumb screws.
  2. Sony KDF-E60A20 Lamp Replacement: step 2, image 1 of 3 Sony KDF-E60A20 Lamp Replacement: step 2, image 2 of 3 Sony KDF-E60A20 Lamp Replacement: step 2, image 3 of 3
    • With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
    • With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
    • The back of the lamp housing is now visible.
  3. Sony KDF-E60A20 Lamp Replacement: step 3, image 1 of 3 Sony KDF-E60A20 Lamp Replacement: step 3, image 2 of 3 Sony KDF-E60A20 Lamp Replacement: step 3, image 3 of 3
    • Loosen the 3mm Allen bolt. It will not come out of the lamp housing, but will loosen it to remove the lamp housing from the TV.
    • With the Allen bolt loose, pull the lamp houing slightly back and down,
    • this will remove the lamp in its housing.
  4. Sony KDF-E60A20 Lamp Replacement: step 4, image 1 of 3 Sony KDF-E60A20 Lamp Replacement: step 4, image 2 of 3 Sony KDF-E60A20 Lamp Replacement: step 4, image 3 of 3
    • Here is the old lamp and housing.
    • For the replacement, a complete lamp and housing was chosen. The lamp is individually available. There was not a big difference in cost, to justify the additional steps of replacing the lamp housing.
    • Install the new lamp and housing
  5. Sony KDF-E60A20 Lamp Replacement: step 5, image 1 of 1
    • Result of this $32 repair is a bright fully functioning TV
13 other people completed this guide.
oldturkey03
785,235 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
577 Guides authored
17 Comments
Where did you purchase this bulb for $32?
Wendy Watson - Reply
Mine worked 4 3 hours then stayed off.
Love machine Guaranteed -
I ordered a replacement housing with new bulb in it and with shipping it was 35. Ordered it thru Sears online and they sent it out next day air. It took five min to swap out
Joker - Reply
Thanks a lot. You saved me money
Alexander Ritchie - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 45
All Time: 24,963
