Sony Handycam HDR­-CX220 Buttons Replacement
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: step 1, image 1 of 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: step 2, image 1 of 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: step 3, image 1 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: step 3, image 2 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: step 3, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: step 4, image 1 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement: step 4, image 2 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: step 5, image 1 of 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: step 6, image 1 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: step 6, image 2 of 3 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: step 6, image 3 of 3
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: step 7, image 1 of 2 Sony Handycam HDR­-CX220 Buttons  Replacement: step 7, image 2 of 2
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
2 other people completed this guide.
Keven
811 Reputation
6 Guides authored
One Comment
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 891
