Sony Handycam DCR-SR42 Flex Cable Replacement
  1. Sony Handycam DCR-SR42 Flex Cable Replacement, Hard Drive: step 1, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement, Hard Drive: step 1, image 2 of 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Flex Cable Replacement: step 2, image 1 of 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Flex Cable Replacement: step 3, image 1 of 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Flex Cable Replacement: step 4, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 4, image 2 of 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Flex Cable Replacement: step 5, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 5, image 2 of 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Flex Cable Replacement: step 6, image 1 of 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Flex Cable Replacement: step 7, image 1 of 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Flex Cable Replacement, Internal Components: step 8, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement, Internal Components: step 8, image 2 of 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Flex Cable Replacement: step 9, image 1 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 9, image 2 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 9, image 3 of 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Flex Cable Replacement: step 10, image 1 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 10, image 2 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 10, image 3 of 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Flex Cable Replacement: step 11, image 1 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 11, image 2 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 11, image 3 of 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Flex Cable Replacement: step 12, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 12, image 2 of 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Flex Cable Replacement: step 13, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 13, image 2 of 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Flex Cable Replacement, Flex Cable: step 14, image 1 of 1
    • Remove the 5 3mm Phillips #00 Screws from the screen assembly.
  15. Sony Handycam DCR-SR42 Flex Cable Replacement: step 15, image 1 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 15, image 2 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 15, image 3 of 3
    • Carefully lift up the sound chip and peel the flex cable off the screen case.
    • Lift off the plastic bracket from the hinge.
  16. Sony Handycam DCR-SR42 Flex Cable Replacement: step 16, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 16, image 2 of 2
    • Remove the screen from the plastic case by pulling the flex cable and sound chip through the hole in the case.
  17. Sony Handycam DCR-SR42 Flex Cable Replacement: step 17, image 1 of 1
    • Turn the hinge sideways and remove the two 4mm Phillips #00 screws from the side of the screen.
  18. Sony Handycam DCR-SR42 Flex Cable Replacement: step 18, image 1 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 18, image 2 of 3 Sony Handycam DCR-SR42 Flex Cable Replacement: step 18, image 3 of 3
    • Use the plastic opening tool to remove the plastic hinge covers and expose the metal hinge.
    • Unwrap the flex cable from around the hinge.
  19. Sony Handycam DCR-SR42 Flex Cable Replacement: step 19, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 19, image 2 of 2
    • Use the plastic opening tool to open the screen case.
  20. Sony Handycam DCR-SR42 Flex Cable Replacement: step 20, image 1 of 2 Sony Handycam DCR-SR42 Flex Cable Replacement: step 20, image 2 of 2
    • Unplug the flex cable from the sound chip.
    • Unplug the flex cable from the screen chip.
Dan Muller
1,020 Reputation
5 Guides authored
Baylor, Team 7-13, Williams Spring 2015 Member of Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 34
All Time: 4,592
