Installing Sony Handycam DCR-DVD103 Laser Disc
  1. Installing Sony Handycam DCR-DVD103 Laser Disc, Battery: step 1, image 1 of 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Installing Sony Handycam DCR-DVD103 Laser Disc: step 2, image 1 of 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Installing Sony Handycam DCR-DVD103 Laser Disc, Outer Cover: step 3, image 1 of 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Installing Sony Handycam DCR-DVD103 Laser Disc: step 4, image 1 of 2 Installing Sony Handycam DCR-DVD103 Laser Disc: step 4, image 2 of 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Installing Sony Handycam DCR-DVD103 Laser Disc: step 5, image 1 of 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Installing Sony Handycam DCR-DVD103 Laser Disc: step 6, image 1 of 2 Installing Sony Handycam DCR-DVD103 Laser Disc: step 6, image 2 of 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Installing Sony Handycam DCR-DVD103 Laser Disc: step 7, image 1 of 2 Installing Sony Handycam DCR-DVD103 Laser Disc: step 7, image 2 of 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Installing Sony Handycam DCR-DVD103 Laser Disc: step 8, image 1 of 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Installing Sony Handycam DCR-DVD103 Laser Disc: step 9, image 1 of 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Installing Sony Handycam DCR-DVD103 Laser Disc, Laser Disc: step 10, image 1 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc, Laser Disc: step 10, image 2 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc, Laser Disc: step 10, image 3 of 3
    • Remove (1) 2.9mm screw from under the eye piece.
    • Remove (1) 2.9mm screw from above the eye piece.
    • Remove (4) copper strips from bellow the eye piece.
    • Pull off the eye piece assembly.
  11. Installing Sony Handycam DCR-DVD103 Laser Disc: step 11, image 1 of 1
    • Pull off back cover. Caution: Be careful not to tear any copper strips in the process.
    • Remove (4) copper strips in order to pull off eye piece.
  12. Installing Sony Handycam DCR-DVD103 Laser Disc: step 12, image 1 of 1
    • Remove (4) 3.6mm wide head screws on the laser reader.
    • Note: There are rubber rings around screws that easily fall off.
  13. Installing Sony Handycam DCR-DVD103 Laser Disc: step 13, image 1 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 13, image 2 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 13, image 3 of 3
    • Unplug copper strip and lift up.
    • Pull off tape over 2.3mm screw.
    • Remove (1) 2.3mm screw from under the tape.
  14. Installing Sony Handycam DCR-DVD103 Laser Disc: step 14, image 1 of 2 Installing Sony Handycam DCR-DVD103 Laser Disc: step 14, image 2 of 2
    • Pull the copper strip, marked by the red rectangle, through the hole behind it, marked with the yellow rectangle.
  15. Installing Sony Handycam DCR-DVD103 Laser Disc: step 15, image 1 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 15, image 2 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 15, image 3 of 3
    • Remove (3) 2.9mm screws from top circuit board.
    • Note: Circuit board will resist trying to be pulled off so pull it off with care but still firmly.
    • Lift up circuit board and remove (1) 2.9mm screw underneath.
    • Pull out copper plate with rubber insulator on it.
  16. Installing Sony Handycam DCR-DVD103 Laser Disc: step 16, image 1 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 16, image 2 of 3 Installing Sony Handycam DCR-DVD103 Laser Disc: step 16, image 3 of 3
    • Remove tape over copper strip in the bottom left corner and pull out copper strip.
    • Remove laser reader assembly.
Lauren
253 Reputation
2 Guides authored
Cal Poly, Team 7-44, Regan Winter 2011 Member of Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 3,445
