Introduction
Learn how to replace the microphones inside your Sony H.ear On 2!
Replacing noise canceling microphones requires minimal disassembly but will require you to solder 2 connections.
Note: Headphone symmetry allows for identical replacement procedure for microphone on left and right side.
Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
Use the iFixit plastic opening tool to lift the microphone out of its housing
