Introduction
The Logic Board is the part that the keys hit and translates the signals to the phone.
Remove the back cover by pulling it down, and then take out the battery.
Using a T6 Torx screwdriver, remove the 4 screws.
Keep the phone open with the back cover facing you.
Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
