Sony Ericsson Z500a Keypad Replacement
  1. Sony Ericsson Z500a Keypad Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson Z500a Keypad Replacement, Keypad: step 1, image 2 of 2
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 precision screwdriver, remove the 4 screws.
    • Keep the back cover facing you.
  2. Sony Ericsson Z500a Keypad Replacement: step 2, image 1 of 1
    • Remove the 4 screws using a T6 precision screwdriver.
    • Flip open the phone, and keep the back cover facing you.
  3. Sony Ericsson Z500a Keypad Replacement: step 3, image 1 of 2 Sony Ericsson Z500a Keypad Replacement: step 3, image 2 of 2
    • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
    • There are 2 clamps that lock it to the phone case (1 on each side).
  4. Sony Ericsson Z500a Keypad Replacement: step 4, image 1 of 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
Jory Benitez
1 Reputation
1 Guide authored
Cal Poly, Team 7-12, Maness Spring 2010 Member of Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,734
