Sony Ericsson W810I Case Replacement
  1. Sony Ericsson W810I Case Replacement, Battery: step 1, image 1 of 1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Case Replacement: step 2, image 1 of 1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Case Replacement: step 3, image 1 of 2 Sony Ericsson W810I Case Replacement: step 3, image 2 of 2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I Case Replacement, Case: step 4, image 1 of 3 Sony Ericsson W810I Case Replacement, Case: step 4, image 2 of 3 Sony Ericsson W810I Case Replacement, Case: step 4, image 3 of 3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I Case Replacement: step 5, image 1 of 3 Sony Ericsson W810I Case Replacement: step 5, image 2 of 3 Sony Ericsson W810I Case Replacement: step 5, image 3 of 3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I Case Replacement: step 6, image 1 of 3 Sony Ericsson W810I Case Replacement: step 6, image 2 of 3 Sony Ericsson W810I Case Replacement: step 6, image 3 of 3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I Case Replacement: step 7, image 1 of 3 Sony Ericsson W810I Case Replacement: step 7, image 2 of 3 Sony Ericsson W810I Case Replacement: step 7, image 3 of 3
    • Run the plastic opening tool upwards along that side, removing the housing.
Lucy Bowen
449 Reputation
7 Guides authored
Cuesta, Team 1-7, Zipperian Fall 2011 Member of Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Member
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 4,481
