Installing Sony Ericsson W810I Case
  1. Installing Sony Ericsson W810I Case, Battery: step 1, image 1 of 1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Installing Sony Ericsson W810I Case: step 2, image 1 of 1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Installing Sony Ericsson W810I Case: step 3, image 1 of 2 Installing Sony Ericsson W810I Case: step 3, image 2 of 2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Installing Sony Ericsson W810I Case, Case: step 4, image 1 of 3 Installing Sony Ericsson W810I Case, Case: step 4, image 2 of 3 Installing Sony Ericsson W810I Case, Case: step 4, image 3 of 3
    • Remove the 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the 6.35mm screws with a Torx T6 screwdriver.
  5. Installing Sony Ericsson W810I Case: step 5, image 1 of 3 Installing Sony Ericsson W810I Case: step 5, image 2 of 3 Installing Sony Ericsson W810I Case: step 5, image 3 of 3
    • Run a plastic opening tool along the edge of the antenna cover to remove it.
  6. Installing Sony Ericsson W810I Case: step 6, image 1 of 3 Installing Sony Ericsson W810I Case: step 6, image 2 of 3 Installing Sony Ericsson W810I Case: step 6, image 3 of 3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage.
  7. Installing Sony Ericsson W810I Case: step 7, image 1 of 3 Installing Sony Ericsson W810I Case: step 7, image 2 of 3 Installing Sony Ericsson W810I Case: step 7, image 3 of 3
    • Run the plastic opening tool upwards, removing the housing from left to right.
Lucy Bowen
449 Reputation
7 Guides authored
Cuesta, Team 1-7, Zipperian Fall 2011 Member of Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Member
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 4,491
