Installing Sony Ericsson K750i Joystick
  1. Installing Sony Ericsson K750i Joystick, Battery Cover: step 1, image 1 of 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Installing Sony Ericsson K750i Joystick, Back Casing: step 2, image 1 of 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Installing Sony Ericsson K750i Joystick: step 3, image 1 of 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Installing Sony Ericsson K750i Joystick: step 4, image 1 of 1
    • Remove the casing to expose the camera's components.
  5. Installing Sony Ericsson K750i Joystick, Keypad: step 5, image 1 of 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Installing Sony Ericsson K750i Joystick: step 6, image 1 of 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Installing Sony Ericsson K750i Joystick: step 7, image 1 of 2 Installing Sony Ericsson K750i Joystick: step 7, image 2 of 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Installing Sony Ericsson K750i Joystick, Joystick: step 8, image 1 of 1
    • Use tweezers to get a grip on the joystick
    • Pull off
    • Warning: the green film surrounding the joystick is fragile. Take care not to puncture or rip it.
Abby Evers
202 Reputation
6 Guides authored
UW Stout, Team 1-6, Zhou Fall 2011 Member of UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 6,960
