Sony DVP-FX730 Monitor Replacement
  1. Sony DVP-FX730 Monitor Replacement, Cover: step 1, image 1 of 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: step 2, image 1 of 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: step 3, image 1 of 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: step 4, image 1 of 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: step 5, image 1 of 2 Sony DVP-FX730 Monitor Replacement, Monitor: step 5, image 2 of 2
    • Use your hand to remove the small back cover.
  6. Sony DVP-FX730 Monitor Replacement: step 6, image 1 of 1
    • Remove the two 0.473" pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: step 7, image 1 of 1
    • The screen should now detach from the main device.
    • The screen will still be connected by the wires.
  8. Sony DVP-FX730 Monitor Replacement: step 8, image 1 of 2 Sony DVP-FX730 Monitor Replacement: step 8, image 2 of 2
    • Remove the wires attached to the white base by using the tweezers
  9. Sony DVP-FX730 Monitor Replacement: step 9, image 1 of 2 Sony DVP-FX730 Monitor Replacement: step 9, image 2 of 2
    • Do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: step 10, image 1 of 1
    • The screen should now be completely separated from the main device.
Andrew Ward
93 Reputation
2 Guides authored
Cal Poly, Team 11-21, Maness Winter 2012 Member of Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 10
All Time: 3,021
