Introduction
By having a Phillips 000 screwdriver, this will be an easy task to handle. There are only 6 screws that need to be taken out, then the rest of the case can be easily taken off.
To remove the outer case, open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides and two on the bottom.
Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
