Sony Cyber-shot DSC-W730 LCD Screen Replacement
  1. Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: step 1, image 1 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: step 1, image 2 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: step 1, image 3 of 3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 2, image 3 of 3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 3, image 2 of 2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 4, image 2 of 2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 5, image 1 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 5, image 2 of 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 5, image 3 of 3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: step 6, image 1 of 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: step 6, image 2 of 2
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: step 8, image 2 of 2
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
Jeremy Petchonka
279 Reputation
2 Guides authored
USF Tampa, Team 9-4, Blackwell Winter 2015 Member of USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 Members
12 Guides authored
2 Comments
Excellent tutorial. It helped me a lot. I ve just replaced my LCD with success.
Thank you
joao - Reply
I can record with the camera but I can't see the image while taking photos. Any suggestions?
Robin_o - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 28
All Time: 1,404
