Sony Cyber-shot DSC-W55 Front Case Replacement
  1. Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: step 1, image 2 of 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Front Case Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W55 Front Case Replacement: step 2, image 2 of 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: step 3, image 1 of 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: step 3, image 2 of 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Front Case Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W55 Front Case Replacement: step 4, image 2 of 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Front Case Replacement: step 5, image 1 of 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Front Case Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-W55 Front Case Replacement: step 6, image 2 of 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Front Case Replacement, Front Case: step 7, image 1 of 1
    • Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
  8. Sony Cyber-shot DSC-W55 Front Case Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-W55 Front Case Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-W55 Front Case Replacement: step 8, image 3 of 3
    • Remove the small screw using a Phillips #00 Screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
Andrew Carter
202 Reputation
2 Guides authored
Cal Poly, Team 9-20, Regan Fall 2010 Member of Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Members
18 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 28
All Time: 3,391
