Repairing Sony Cybershot DSC-W5 Speaker
  1. Repairing Sony Cybershot DSC-W5 Speaker, Back Cover: step 1, image 1 of 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Repairing Sony Cybershot DSC-W5 Speaker: step 2, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 2, image 2 of 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Repairing Sony Cybershot DSC-W5 Speaker: step 3, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 3, image 2 of 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Repairing Sony Cybershot DSC-W5 Speaker, LCD Screen: step 4, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker, LCD Screen: step 4, image 2 of 2
    • Remove the two screws holding the circuit board down.
  5. Repairing Sony Cybershot DSC-W5 Speaker: step 5, image 1 of 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Repairing Sony Cybershot DSC-W5 Speaker: step 6, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 6, image 2 of 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 1 of 3 Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 2 of 3 Repairing Sony Cybershot DSC-W5 Speaker: step 7, image 3 of 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Repairing Sony Cybershot DSC-W5 Speaker, Speaker: step 8, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker, Speaker: step 8, image 2 of 2
    • Remove two screws holding down steel backplate.
  9. Repairing Sony Cybershot DSC-W5 Speaker: step 9, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 9, image 2 of 2
    • Now, remove plastic plate that covers the motherboard.
  10. Repairing Sony Cybershot DSC-W5 Speaker: step 10, image 1 of 1
    • RISK of Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors in the camera hold charge that will shock you even though there are no batteries in the camera.
  11. Repairing Sony Cybershot DSC-W5 Speaker: step 11, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 11, image 2 of 2
    • Remove cable.
  12. Repairing Sony Cybershot DSC-W5 Speaker: step 12, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 12, image 2 of 2
    • Disconnect flash cable before completely removing front case.
    • Gently start to remove case.
    • Once cable is free, set aside the front case.
    • RISK of Electric Shock Avoid temptation of touching the circuit board while removing the front case.
  13. Repairing Sony Cybershot DSC-W5 Speaker: step 13, image 1 of 2 Repairing Sony Cybershot DSC-W5 Speaker: step 13, image 2 of 2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug speaker from the motherboard.
    • Replace speaker.
Thomas
133 Reputation
6 Guides authored
Cal Poly, Team 15-50, Garner Spring 2010 Member of Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Members
12 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 18
All Time: 3,618
