Introduction
Steps on how to replace the speaker.
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Remove plastic plate that is covering the motherboard.
Note: It may be useful to write yourself a note as to which way is up.
Disconnect flash cable before completely removing front case.
Gently start to remove case.
Once cable is free, set aside the front case.
The speaker should now be clearly seen on the underside of the camera.
Gently unplug speaker from the motherboard.
Replace speaker.
