Introduction
This guide will teach the user how to take off the front sliding lens cover.
Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
The 4 mm length screws are located on each side and on the bottom of the camera.
2 screws on each side (4 total).
2 screws on bottom.
Gently pry around the front cover using the plastic opening tool.
Carefully separate front cover from body of camera.
Remove the three 4mm length screws located on the inside of the front cover with the Phillips #00 screwdriver.
