Installing Sony Cyber-shot DSC-P9 Outer Casing
  1. Installing Sony Cyber-shot DSC-P9 Outer Casing, Battery: step 1, image 1 of 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Installing Sony Cyber-shot DSC-P9 Outer Casing: step 2, image 1 of 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Installing Sony Cyber-shot DSC-P9 Outer Casing: step 3, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Outer Casing: step 3, image 2 of 2
    • Remove the battery from the camera.
  4. Installing Sony Cyber-shot DSC-P9 Outer Casing, Outer Casing: step 4, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Outer Casing, Outer Casing: step 4, image 2 of 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Installing Sony Cyber-shot DSC-P9 Outer Casing: step 5, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Outer Casing: step 5, image 2 of 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Installing Sony Cyber-shot DSC-P9 Outer Casing: step 6, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Outer Casing: step 6, image 2 of 2
    • Then, pull the front case away from the rest of the camera.
  7. Installing Sony Cyber-shot DSC-P9 Outer Casing: step 7, image 1 of 1
    • After the casing is removed, the camera should look as shown.
Jenna Crawford
50 Reputation
3 Guides authored
Cal Poly, Team 17-25, Amido Spring 2012 Member of Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 15
All Time: 787
