Installing Sony Cyber-shot DSC-P9 Motherboard
  1. Installing Sony Cyber-shot DSC-P9 Motherboard, Battery: step 1, image 1 of 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Installing Sony Cyber-shot DSC-P9 Motherboard: step 2, image 1 of 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Installing Sony Cyber-shot DSC-P9 Motherboard: step 3, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 3, image 2 of 2
    • Remove the battery from the camera.
  4. Installing Sony Cyber-shot DSC-P9 Motherboard, Outer Casing: step 4, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard, Outer Casing: step 4, image 2 of 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Installing Sony Cyber-shot DSC-P9 Motherboard: step 5, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 5, image 2 of 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Installing Sony Cyber-shot DSC-P9 Motherboard: step 6, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 6, image 2 of 2
    • Then, pull the front case away from the rest of the camera.
  7. Installing Sony Cyber-shot DSC-P9 Motherboard: step 7, image 1 of 1
    • After the casing is removed, the camera should look as shown.
  8. Installing Sony Cyber-shot DSC-P9 Motherboard, Lens: step 8, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard, Lens: step 8, image 2 of 2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Installing Sony Cyber-shot DSC-P9 Motherboard: step 9, image 1 of 1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Installing Sony Cyber-shot DSC-P9 Motherboard: step 10, image 1 of 1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Installing Sony Cyber-shot DSC-P9 Motherboard: step 11, image 1 of 1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Installing Sony Cyber-shot DSC-P9 Motherboard: step 12, image 1 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 12, image 2 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 12, image 3 of 3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Installing Sony Cyber-shot DSC-P9 Motherboard: step 13, image 1 of 1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Installing Sony Cyber-shot DSC-P9 Motherboard: step 14, image 1 of 1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Installing Sony Cyber-shot DSC-P9 Motherboard: step 15, image 1 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 15, image 2 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 15, image 3 of 3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
  16. Installing Sony Cyber-shot DSC-P9 Motherboard, Motherboard: step 16, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard, Motherboard: step 16, image 2 of 2
    • Rotate the bottom panel upwards and pull away with your hand.
  17. Installing Sony Cyber-shot DSC-P9 Motherboard: step 17, image 1 of 1
    • Remove the one 2.5mm Phillips #000 screw on the bottom corner of the motherboard.
  18. Installing Sony Cyber-shot DSC-P9 Motherboard: step 18, image 1 of 1
    • Lift the black tab holding the top-left ribbon cable in place with the spudger tool.
    • Remove the ribbon cable with the spudger by carefully pulling the cable directly out of the slot.
    • Take care not to rip the ribbon cable when pulling it out.
  19. Installing Sony Cyber-shot DSC-P9 Motherboard: step 19, image 1 of 1
    • Lift the black tab that locks the orange ribbon cable in place.
    • Remove the ribbon cable by gently pulling it out of the slot with the spudger.
    • Take care not to rip the ribbon cable when pulling it out, and be mindful of a second cable beneath the first.
  20. Installing Sony Cyber-shot DSC-P9 Motherboard: step 20, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 20, image 2 of 2
    • Remove the second ribbon cable below the first one by gently pulling it out of the slot with the spudger.
  21. Installing Sony Cyber-shot DSC-P9 Motherboard: step 21, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 21, image 2 of 2
    • Remove the ribbon cable to the right of the bottom two ribbon cables with the spudger.
  22. Installing Sony Cyber-shot DSC-P9 Motherboard: step 22, image 1 of 2 Installing Sony Cyber-shot DSC-P9 Motherboard: step 22, image 2 of 2
    • Pull the motherboard out of the slot on the side of the camera where the lens used to be attached.
  23. Installing Sony Cyber-shot DSC-P9 Motherboard: step 23, image 1 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 23, image 2 of 3 Installing Sony Cyber-shot DSC-P9 Motherboard: step 23, image 3 of 3
    • Lift the motherboard away from the camera.
    • Detach the final ribbon cable connecting the motherboard to the rest of the camera.
  24. Installing Sony Cyber-shot DSC-P9 Motherboard: step 24, image 1 of 1
    • The motherboard should now be fully disconnected from the rest of the camera.
Robert Potter
41 Reputation
1 Guide authored
Cal Poly, Team 17-25, Amido Spring 2012 Member of Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,240
