Installing Sony Cyber-shot DSC-P52 Motherboard Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly, Outer Case: step 1, image 1 of 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 2, image 1 of 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 3, image 1 of 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 4, image 1 of 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 5, image 1 of 1
    • Open the case as shown.
  6. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 6, image 1 of 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 7, image 1 of 1
    • Pull the ribbon cable out.
  8. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly, Motherboard Assembly: step 8, image 1 of 1
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 9, image 1 of 1
    • Remove the cable on the back side of the motherboard.
  10. Installing Sony Cyber-shot DSC-P52 Motherboard Assembly: step 10, image 1 of 1
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
Trevor
295 Reputation
6 Guides authored
Cal Poly, Team 3-43, Regan Winter 2011 Member of Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Members
20 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 224
