Sony Cyber-shot DSC-P52 LCD Replacement
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: step 1, image 1 of 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: step 2, image 1 of 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: step 3, image 1 of 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: step 4, image 1 of 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: step 5, image 1 of 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: step 6, image 1 of 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: step 7, image 1 of 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: step 8, image 1 of 1
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: step 9, image 1 of 1
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: step 10, image 1 of 1
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: step 11, image 1 of 1
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: step 12, image 1 of 1
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: step 13, image 1 of 1
    • Repeat steps in reverse order to reassemble the camera
Mark
13 Reputation
1 Guide authored
Cal Poly, Team 3-43, Regan Winter 2011 Member of Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Members
20 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 16
All Time: 2,497
