Introduction
This guide will demonstrate how to replace the Memory Card Reader. This will fix the "Unable to read memory card" Error.
Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
Detach the smaller ribbon cables by sliding them out.
Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
