Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
Hold the boombox handle at an angle to access the screws behind the CD player.
Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
Gently separate the front panel from the back panel.
Remove the two connections holding the front panel to boombox.
One connection is located on the upper left hand side of the main circuit board.
The other is a large white strip slightly to the right of the cassette player.
Remove the front panel.
Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
Unscrew the 5mm screw shown in the photo.
Note the small latch on the side of assembly as you remove the motor.
Remove the motor belt from its axle.
Awesome thank you very much just changed the belt on one couldn't have done it without these instructions
4 other people completed this guide.
3 Comments
need belt for cassette replace
need the belt for the cassette player
First, be sure to have a #1 pt screwdriver with at least a 5” shaft(not counting the handle) length. Second, pay attention to where the screws under the handle are located. Third, mark the top of the connectors with a sharpie or such instrument to be sure you are replacing the connector in the correct position.
