Sony BDP-S3700 Disc Drive Replacement
  1. Sony BDP-S3700 Disc Drive Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3700 Disc Drive Replacement, Front Panel: step 1, image 2 of 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Disc Drive Replacement: step 2, image 1 of 2 Sony BDP-S3700 Disc Drive Replacement: step 2, image 2 of 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Disc Drive Replacement: step 3, image 1 of 2 Sony BDP-S3700 Disc Drive Replacement: step 3, image 2 of 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Disc Drive Replacement: step 4, image 1 of 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Disc Drive Replacement, Disc Drive: step 5, image 1 of 3 Sony BDP-S3700 Disc Drive Replacement, Disc Drive: step 5, image 2 of 3 Sony BDP-S3700 Disc Drive Replacement, Disc Drive: step 5, image 3 of 3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Disc Drive Replacement: step 6, image 1 of 2 Sony BDP-S3700 Disc Drive Replacement: step 6, image 2 of 2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Disc Drive Replacement: step 7, image 1 of 1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
3 other people completed this guide.
Luiz Barreto
627 Reputation
5 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2017 Member of USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Members
5 Guides authored
2 Comments
do you know how I can find a replacement power socket for the pcb on a sony bluray player like the one on this item?
It is the yellow colored socket on this model and still used on most Sony players still in production that use an external AC adapter.
cmfic1 - Reply
Bei mein dvd Player geht das Netflix nicht und ich habe keine dvd da zu bekommen
Ramona Piekarski - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 4,876
