Sony BDP-BX520 Disc Reader Replacement
  1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: step 1, image 1 of 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Disc Reader Replacement: step 2, image 1 of 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Disc Reader Replacement: step 3, image 1 of 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Disc Reader Replacement, Top Case: step 4, image 1 of 1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Disc Reader Replacement: step 5, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 5, image 2 of 2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Disc Reader Replacement, Front Panel: step 6, image 1 of 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Disc Reader Replacement: step 7, image 1 of 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Disc Reader Replacement: step 8, image 1 of 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Disc Reader Replacement: step 9, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 9, image 2 of 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: step 10, image 1 of 1
    • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
    • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
  11. Sony BDP-BX520 Disc Reader Replacement: step 11, image 1 of 1
    • Eject the disc tray by pushing the left button on the front of the device.
    • Unplug the device once the disc tray is open.
  12. Sony BDP-BX520 Disc Reader Replacement: step 12, image 1 of 1
    • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
  13. Sony BDP-BX520 Disc Reader Replacement: step 13, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 13, image 2 of 2
    • Once the clips are free, lift the top cover of the disc tray up.
    • This should take minimal force.
  14. Sony BDP-BX520 Disc Reader Replacement: step 14, image 1 of 1
    • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
  15. Sony BDP-BX520 Disc Reader Replacement: step 15, image 1 of 3 Sony BDP-BX520 Disc Reader Replacement: step 15, image 2 of 3 Sony BDP-BX520 Disc Reader Replacement: step 15, image 3 of 3
    • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
    • Once free the white 24 pin ribbon should slip right out.
  16. Sony BDP-BX520 Disc Reader Replacement: step 16, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 16, image 2 of 2
    • Carefully lift up the disc reader. It is still attached by a cable underneath!
  17. Sony BDP-BX520 Disc Reader Replacement: step 17, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 17, image 2 of 2
    • Gently pull out the white 13 pin cable from the disc reader.
Kyle Smit
243 Reputation
2 Guides authored
Cal Poly, Team 8-41, Amido Winter 2015 Member of Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,266
