Sonos Connect Fuse Replacement
  1. Sonos Connect Fuse Replacement, Bottom Part: step 1, image 1 of 1
    • Remove the rubber pads and unscrew
  2. Sonos Connect Fuse Replacement, Continue to unscrew: step 2, image 1 of 1
    • Take care not to damage the wires of the Wi-Fi antennas which are very bothersome.
  3. Sonos Connect Fuse Replacement, Unclip the top cover: step 3, image 1 of 2 Sonos Connect Fuse Replacement, Unclip the top cover: step 3, image 2 of 2
    • By using a screwdriver inserted through each of the 8 peripheral slots, you can access the clips of the top cover.
  4. Sonos Connect Fuse Replacement, Access under the top cover: step 4, image 1 of 1
    • Continue unscrewing (there is a screw under the seal).
  5. Sonos Connect Fuse Replacement, Locate the fuse: step 5, image 1 of 1
    • It's a soldered fuse. You will need to desolder it from the back in order to replace it.
  6. Sonos Connect Fuse Replacement, Replacement fuse: step 6, image 1 of 1
    • About 1$
    • 250V 5A T fuse (time delay).
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
YvesG
290 Reputation
2 Guides authored
One Comment
Bravo
Ce tuto peux rendre service a des consommateurs abusés par la sociète Sonos .
Merci
bruno vinay - Reply
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 93
All Time: 2,053
