Sonos Roam 2 Outer Shell Replacement
    1. Sonos Roam 2 Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 Sonos Roam 2 Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 Sonos Roam 2 Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
      • Stand the speaker on either end so that it's vertical.
      • Wedge your opening pick between the speaker and the rubber triangle on the end of the speaker.
      • There is a layer of adhesive you'll have to get through in order to take off the rubber end.
      • Wiggle the pick back and forth and drag the pick around the edges to break through this adhesive.
      • This may take a decent amount of time and effort as the adhesive can be a little stubborn.
      • Completely remove the rubber triangle.
      Ask FixBot
    2. Sonos Roam 2 Outer Shell Replacement: step 2, image 1 of 2 Sonos Roam 2 Outer Shell Replacement: step 2, image 2 of 2
      • Flip the speaker over and begin working on the rubber triangle on the other side.
      • Wedge your opening pick between the speaker and the rubber triangle. Wiggle the pick back and forth and drag the pick around the edges to break through the adhesive.
      • It may take a decent amount of time and effort to break through the adhesive.
      Ask FixBot
    3. Sonos Roam 2 Outer Shell Replacement: step 3, image 1 of 2 Sonos Roam 2 Outer Shell Replacement: step 3, image 2 of 2
      • Remove the two 7.5 mm screws using a T6 Torx screwdriver.
      • Flip the speaker over and remove the other two 7.5 mm screws using a T6 Torx screwdriver.
      Ask FixBot
    4. Sonos Roam 2 Outer Shell Replacement: step 4, image 1 of 3 Sonos Roam 2 Outer Shell Replacement: step 4, image 2 of 3 Sonos Roam 2 Outer Shell Replacement: step 4, image 3 of 3
      • Insert your opening pick between the outer shell and the main body.
      • Work your way along the seam from top to bottom, gently prying at intervals to break the adhesive bond.
      • When the outer shell is adequately loosened, lift and remove the outer shell from the speaker assembly.
      Ask FixBot
2 other people completed this guide.
Joseph Stewart
613 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 74
All Time: 286
