Sonos Playbase Bottom Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Sonos Playbase Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 3 Sonos Playbase Bottom Panel Replacement, Bottom Panel: step 1, image 2 of 3 Sonos Playbase Bottom Panel Replacement, Bottom Panel: step 1, image 3 of 3
      Tool used on this step:
      Pro Tech Toolkit
      $79.95
      Buy
      • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
      • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
      • Melt the adhesive with an iOpener for ease of opening
      • Use a Metal Spudger if the plastic spudgers do not work.
      • Take care to avoid damaging the plastic or the device if using a metal spudger.
      Ask FixBot
    2. Sonos Playbase Bottom Panel Replacement: step 2, image 1 of 2 Sonos Playbase Bottom Panel Replacement: step 2, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
      • Remove the seven 44mm T-20 screws by turning counter-clockwise.
      • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
      • Record where each screw belongs for easier reassembly.
      Ask FixBot
    3. Sonos Playbase Bottom Panel Replacement: step 3, image 1 of 2 Sonos Playbase Bottom Panel Replacement: step 3, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
      • Use a metal spudger if plastic openers do not work.
      Ask FixBot
George Slivka
341 Reputation
3 Guides authored
Cal Poly, Team S17-G2, White Fall 2018 Member of Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Members
95 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 186
