Sonos Play 5 Front Panel Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Sonos Play 5 Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
      • Flip the speaker upside down.
      • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
      Ask FixBot
    2. Sonos Play 5 Front Panel Assembly Replacement: step 2, image 1 of 2 Sonos Play 5 Front Panel Assembly Replacement: step 2, image 2 of 2
      • Remove eight 10mm Phillips #2 screws
      • Remove the bottom panel by pulling upwards.
      • Be very gentle with the ends of the three antennas. They are very fragile.
      Ask FixBot
    3. Sonos Play 5 Front Panel Assembly Replacement: step 3, image 1 of 3 Sonos Play 5 Front Panel Assembly Replacement: step 3, image 2 of 3 Sonos Play 5 Front Panel Assembly Replacement: step 3, image 3 of 3
      • Flip the device so that the grille is facing up.
      • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
      • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
      • Gently pull up on the grille, removing it from the front panel.
      Ask FixBot
    4. Sonos Play 5 Front Panel Assembly Replacement: step 4, image 1 of 1
      • Remove the six 8mm Phillips #2 screws.
      • Remove the two 10mm Phillips #2 screws.
      Ask FixBot
    5. Sonos Play 5 Front Panel Assembly Replacement: step 5, image 1 of 2 Sonos Play 5 Front Panel Assembly Replacement: step 5, image 2 of 2
      • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
      • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
      • Gently pull up on the face plate to ensure it has been detached from the enclosure.
      • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
      Ask FixBot
    6. Sonos Play 5 Front Panel Assembly Replacement: step 6, image 1 of 3 Sonos Play 5 Front Panel Assembly Replacement: step 6, image 2 of 3 Sonos Play 5 Front Panel Assembly Replacement: step 6, image 3 of 3
      • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
      • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
      • The faceplate assembly is now fully detached from the rest of the speaker.
      Ask FixBot
Steven Gioiosa
274 Reputation
2 Guides authored
USF Tampa, Team S3-G6, Sullivan Spring 2017 Member of USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 245
