Introduction
If the motherboard has a short circuit or a blown capacitor your Sonos Play one will either not function properly or not function at all. This guide will show the steps on how to disassemble and replace the motherboard.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, pry open the top cap containing the power and volume button.
Vertically remove the top cap.
Using a plastic opening tool, remove the grey tape from both sides of the device.
Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
You will now be able to remove the rear housing cover.
Remove the two 6 mm Torx #6 screws securing the communications board to the motherboard.
Using your fingers, detach and remove the communications board from the motherboard.
7 other people completed this guide.
15 Comments
On a Play 1 r524 and r525 are blown. What are these.and how do I get replacements
Same here. r524 and r525 look blown. Have you been able to identify their values? Did you find any further damage? Have you been able to repair it?
The parts has 1R00 printed on them. 1R= 1 Ohm resistor. You can open an old electronic gadget or look at an old PC-motherboard and see if you find one there. It’s normally hard find surface mounted resistors in local stores…
I have two blown components. Here is a screenshot https://web.capture-app.com/share/d77cb9...
And here is the place on the motherboard from the picture in this guide. https://web.capture-app.com/share/89a940...
I cant see any other blown components on my board.
Anyone knows what the components are?
I have a Sonos Play 1 with also R524 and 525 blown. I see on a ‘good’ board that both these SMD resistors are 1R10, that’s 1,1 ohm. Did somebody had succes in replacing the 2 resistors resulting in a working Sonos Play 1?
has anyone tried adding a “line in “ for those?
I am looking for a component value for C303 on the Play:1 motherboard. It is (was) a 1206?? surface mount capacitor on the bottom side of the motherboard to the left of the Ethernet port. It is cracked crumbled and charred so I think replacing it may bring life back to the device. If anyone can provide the value, greatly appreciated!
Still not any wiser on where to get a new motherboard?
the R178 resistor on my board went dead. Anyone can look it up on their sonos 1
r178 is located on the other side, just underneath the most blown resistors R525 , R423 and R524
I see still nobody has a clue where to buy a new motherboard for the sonos play 1?
Please advice?
Hello,
What are the values / refs of TH301 & MOV301 ? It is near the AC input
Thx for your answer
Br Roland
