Introduction
If the screen on the Sonos Play 1 is dented, cracked or damaged, it may interfere with audio performance and may cause damage to the speakers. In order to prevent damage to the speakers and increase the devices performance, the exterior screen protecting the internal housing of the speakers will need to be replaced. This guide will demonstrate this process of removing the screen.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
12 other people completed this guide.
6 Comments
Where can you purchase a replacement screen please? I dented mine by accident.
where to buy the replacement screen?
Thanks for this guide, had a small but noticeable dent for years, decided it was time to take it out, really strightforward but this guide helps to stop unintended damage working out which bits are removeable!
