Sonos One Protective Cover Replacement
  1. Sonos One Protective Cover Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 3 of 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: step 2, image 1 of 3 Sonos One Protective Cover Replacement: step 2, image 2 of 3 Sonos One Protective Cover Replacement: step 2, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Protective Cover Replacement: step 3, image 1 of 2 Sonos One Protective Cover Replacement: step 3, image 2 of 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: step 4, image 1 of 3 Sonos One Protective Cover Replacement: step 4, image 2 of 3 Sonos One Protective Cover Replacement: step 4, image 3 of 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: step 5, image 1 of 2 Sonos One Protective Cover Replacement: step 5, image 2 of 2
    • Slide the protective cover upwards to remove.
Marcus Glowa
914 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
6 Guides authored
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 68
All Time: 4,670
