This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Sonos Connect:Amp Fuse Replacement
    1. Sonos Connect:Amp Fuse Replacement, Bottom Part: step 1, image 1 of 1
      • Remove the rubber pads and unscrew.
      Ask FixBot
    2. Sonos Connect:Amp Fuse Replacement, Continue to unscrew: step 2, image 1 of 1
      • Take care not to damage the wires of the Wi-Fi antennas which are very bothersome.
      Ask FixBot
    3. Sonos Connect:Amp Fuse Replacement, Unclip the top cover: step 3, image 1 of 2 Sonos Connect:Amp Fuse Replacement, Unclip the top cover: step 3, image 2 of 2
      • By using a screwdriver inserted through each of the 8 peripheral slots, you can access the snap fits of the top cover.
      Ask FixBot
    4. Sonos Connect:Amp Fuse Replacement, Access under the top cover: step 4, image 1 of 1
      • Continue unscrewing (there is a screw under the seal).
      Ask FixBot
    5. Sonos Connect:Amp Fuse Replacement, Locate the fuse: step 5, image 1 of 1
      • It's a soldered fuse. You will need to desolder it from the back in order to replace it.
      Ask FixBot
    6. Sonos Connect:Amp Fuse Replacement, Replacement fuse: step 6, image 1 of 1
      • About 1$
      • 250V 5A T fuse (time delay).
      Ask FixBot
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
YvesG
290 Reputation
2 Guides authored
1 Guide Comment
Bravo
Ce tuto peux rendre service a des consommateurs abusés par la sociète Sonos .
Merci
bruno vinay - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 141
All Time: 4,216
