This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Somfy Inis Uno Shutter Control Capacitor Replacement
      • First, pull the control unit out of its housing in the flush-mounted box. To do this, hold the cover on the left and right sides and pull while wiggling it side to side to release the contacts.
      Ask FixBot
      • The cover should be removed to facilitate the repair. To do this, simply pull it forward to unplug it.
      Ask FixBot
      • Use a flathead screwdriver to open the tabs of the housing.
      Ask FixBot
      • Once the housing is open, you can remove the two boards from the housing.
      • Warning: There may still be voltage present, as the capacitor stores electricity!
      Ask FixBot
      • Insert instructions here.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Sebastian Schefold
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 53
All Time: 94
