Solio CLASSIC2 Disconnecting the Battery
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Solio CLASSIC2 Disconnecting the Battery, Disconnecting the Battery: step 1, image 1 of 1
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      Ask FixBot
    2. Solio CLASSIC2 Disconnecting the Battery: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      Ask FixBot
    3. Solio CLASSIC2 Disconnecting the Battery: step 3, image 1 of 3 Solio CLASSIC2 Disconnecting the Battery: step 3, image 2 of 3 Solio CLASSIC2 Disconnecting the Battery: step 3, image 3 of 3
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      Ask FixBot
    4. Solio CLASSIC2 Disconnecting the Battery: step 4, image 1 of 2 Solio CLASSIC2 Disconnecting the Battery: step 4, image 2 of 2
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      Ask FixBot
    5. Solio CLASSIC2 Disconnecting the Battery: step 5, image 1 of 2 Solio CLASSIC2 Disconnecting the Battery: step 5, image 2 of 2
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      Ask FixBot
    6. Solio CLASSIC2 Disconnecting the Battery: step 6, image 1 of 2 Solio CLASSIC2 Disconnecting the Battery: step 6, image 2 of 2
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      Ask FixBot
Johnny Tran
311 Reputation
3 Guides authored
Cal Poly, Team 4-28, Amido Fall 2013 Member of Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 248
