Up to 20% off select tools
SolarLog 300 Corrupt Firmware Fix
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
34
Past 30 Days:
87
All Time:
3,068
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Note following the guide will void your warranty. In case the product is still under warranty, contract the manufacturer for a replacement.
    1. SolarLog 300  Corrupt Firmware Fix, Open back panel: step 1, image 1 of 3 SolarLog 300  Corrupt Firmware Fix, Open back panel: step 1, image 2 of 3 SolarLog 300  Corrupt Firmware Fix, Open back panel: step 1, image 3 of 3
      • Remove all 4 screws with Torx T10 bit/driver (See Picture 2)
      • Then, remove the back panel to reveal the main PCB (See Picture 3)
      Ask FixBot
    2. SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: step 2, image 1 of 3 SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: step 2, image 2 of 3 SolarLog 300  Corrupt Firmware Fix, Flip Main PCB: step 2, image 3 of 3
      • Slide the main PCB downwards, just a few millimeters for the top side to be lifted.(See Picture 1)
      • Lift the topside of the PCB but still keeping the bottom side stationary. (See Picture 2)The main reason therefore, is the display cable is conneted at the bottom side.(Indicated in yellow on the 3rd picture)
      • You will see the microSD card on the board.
      Ask FixBot
    3. SolarLog 300  Corrupt Firmware Fix, Remove MicroSD card: step 3, image 1 of 1
      • Remove the MicroSD card by pressing inward to pop out.
      Ask FixBot
    4. SolarLog 300  Corrupt Firmware Fix, Download New Firmware: step 4, image 1 of 1
      Ask FixBot
      • By using a microSD card reader insert the new SD card into your computer.
      • Copy the downloaded firmware file to the new empty microSD card.
      • Rename the firmware file to: firmware_update.bin
      Ask FixBot
      • Put the microSD card back into the unit and reverse the steps you took to take it apart.
      • Power up the unit and the screen will show FW indicating that the new firmware update has started.
      • Note all previous configuration and save data will be lost.
      Ask FixBot
Author
with
Niel Lambrechts
272 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 87
All Time: 3,068
