Solar garden led light with dimming along the string
  1. Solar garden led light with dimming along the string, Solar garden led light with dimming along the string: step 1, image 1 of 3 Solar garden led light with dimming along the string, Solar garden led light with dimming along the string: step 1, image 2 of 3 Solar garden led light with dimming along the string, Solar garden led light with dimming along the string: step 1, image 3 of 3
    • Thermal images of 'hot' and 'normal' leds. Green arrows show wires and red arrows shows leds. The 'normal' led and wire is hardly visible. Ignore temperatures they weren't positioned accurately. Colour scale auto-generated.
    • Optical image shows a failed led with shrink-fit sleve removed (leg broken) and an intact led for comparison
  2. Solar garden led light with dimming along the string: step 2, image 1 of 1
    • re-assembled solar panel and led light string
You don't have to reattach the section of leds and wire that has been cut off, but the string will of course be shorter. Just make sure the exposed ends cannot touch (ie cut one wire shorter than the other and insulate with tape or shrink-fit.)
Normally led's fail harmlessly open circuit (high resistance) but the above problem led failed with a low resistance of 200 Ohms so was taking enough current to drop the surrounding voltages (and thus heating itself up to be visible in the far infra red imaging camera).
Open circuit failure was due to corrosion and breakage of the led arm(s) due to rain ingress. Close circuit failure was probably due to corrosion product bridging the power wires. Which failure occurs depends on build quality ie the amount on water ingress/egress, how much corrosive soldering flux was not washed away, etc. etc
Garden solar lamps are often made of poor quality materials and poorly assembled. They seldom last more than 3-6 years. Perhaps they would last longer if sealed with silicone rubber or similar?
3 other people completed this guide.
Dave Empson
4,060 Reputation
38 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 58
All Time: 1,318
