Introduction
The volume buttons on the speaker are two black buttons located on the front of the device. The volume up button, which increases the sound of the speaker, is on the right side shaped like a plus sign (+) and the volume down button, which decreases the sound of the speaker, is on the left side shaped like a minus sign (-).
Using the metal spudger with the smaller sized tip, pry the front face plate from the bottom half of the speaker by inserting the metal spudger edge into the the middle groove and applying pressure until entry.
Insert another metal spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple metal spudgers to keep plates separated if necessary.
Locate the black plastic volume buttons on each side of the back of the speaker face.
A piece of black tape on the side panel may also be covering the yellow connector tip that holds the volume button in place. Remove the black tape if necessary.
Using the plastic spudger, pry the button from the front plate of the speaker. The volume button is connected to the speaker by a plastic tab that has blue glue holding it down. The entire volume button can be removed from the front plate by carefully using the spudger to lift it up until it comes off.
