Soft Leather Journal Cover Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
101
All Time:
833
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the cover of a soft leather journal.
You will cut off the old cover, reinforce the spine, and glue new leather on. This material can be thrifted for cost efficiency.
Journals hold sentimental value. However, when they fall apart—especially if the leather crumbles and causes a mess—users tend to abandon them only half-filled. This is especially wasteful when the journal or pages are of good quality. Quick fixes like electrical tape can be unsightly and unsustainable (due to peeling and frequent replacing).
When attaching the new cover, you will glue it directly to the front and back sheets of the journal. Take a picture if you want to preserve its contents.
    1. Soft Leather Journal Cover Replacement, Cover: step 1, image 1 of 2 Soft Leather Journal Cover Replacement, Cover: step 1, image 2 of 2
      • Gather your old journal, required tools and parts, and a large item that can be used as a weight.
      • Your stiff fabric will reinforce the spine, and your scrap leather will become your new cover. They can be different materials as long as they serve a similar function.
      Ask FixBot
    2. Soft Leather Journal Cover Replacement: step 2, image 1 of 3 Soft Leather Journal Cover Replacement: step 2, image 2 of 3 Soft Leather Journal Cover Replacement: step 2, image 3 of 3
      • Cut the cover and spine off from the main journal body with an X-ACTO knife.
      • Keep the main block of pages intact.
      • Save the cover for Step 5.
      Ask FixBot
    3. Soft Leather Journal Cover Replacement: step 3, image 1 of 1
      • Create the spine reinforcement:
      • Measure the height and width of the journal's spine onto your stiff fabric.
      • Subtract one inch from your height, and add two inches to your width.
      Ask FixBot
    4. Soft Leather Journal Cover Replacement: step 4, image 1 of 1
      • Cut the stiff fabric into a small rectangle with your modified measurements.
      Ask FixBot
    5. Soft Leather Journal Cover Replacement: step 5, image 1 of 3 Soft Leather Journal Cover Replacement: step 5, image 2 of 3 Soft Leather Journal Cover Replacement: step 5, image 3 of 3
      • Apply a thin layer of PVA glue to the spine of the journal with a paintbrush.
      • Press the spine firmly into the center of the stiff fabric for one minute.
      • PVA glue dries fast, so work quickly.
      Ask FixBot
    6. Soft Leather Journal Cover Replacement: step 6, image 1 of 3 Soft Leather Journal Cover Replacement: step 6, image 2 of 3 Soft Leather Journal Cover Replacement: step 6, image 3 of 3
      • Create the new cover:
      • Press the original cover flat onto the interior of your scrap leather.
      • Trace around the original cover with chalk.
      Ask FixBot
    7. Soft Leather Journal Cover Replacement: step 7, image 1 of 3 Soft Leather Journal Cover Replacement: step 7, image 2 of 3 Soft Leather Journal Cover Replacement: step 7, image 3 of 3
      • Cut on the chalk outline with scissors, extending the length beyond the right side by four inches.
      • This extra length will become the cover flap.
      Ask FixBot
    8. Soft Leather Journal Cover Replacement: step 8, image 1 of 3 Soft Leather Journal Cover Replacement: step 8, image 2 of 3 Soft Leather Journal Cover Replacement: step 8, image 3 of 3
      • Roll the journal onto the new cover to ensure a correct fit.
      Ask FixBot
    9. Soft Leather Journal Cover Replacement: step 9, image 1 of 2 Soft Leather Journal Cover Replacement: step 9, image 2 of 2
      • Spread a thin, even layer of PVA glue onto the front and back of the journal.
      • Make sure to coat the overhang of the stiff fabric, but DO NOT glue the spine.
      Ask FixBot
    10. Soft Leather Journal Cover Replacement: step 10, image 1 of 3 Soft Leather Journal Cover Replacement: step 10, image 2 of 3 Soft Leather Journal Cover Replacement: step 10, image 3 of 3
      • Left align the journal (front-side down) onto the interior of your new cover, spine facing towards the center.
      • Gently roll the journal onto its back sheet until it meets the chalk line.
      • Place a weight on top of the journal for at least 30 minutes.
      Ask FixBot
    11. Soft Leather Journal Cover Replacement: step 11, image 1 of 3 Soft Leather Journal Cover Replacement: step 11, image 2 of 3 Soft Leather Journal Cover Replacement: step 11, image 3 of 3
      • Create the string closure:
      • Trace an 18-inch long by half-inch tall rectangle onto the interior of your excess scrap leather.
      Ask FixBot
    12. Soft Leather Journal Cover Replacement: step 12, image 1 of 2 Soft Leather Journal Cover Replacement: step 12, image 2 of 2
      • Cut on the chalk outline.
      Ask FixBot
    13. Soft Leather Journal Cover Replacement: step 13, image 1 of 2 Soft Leather Journal Cover Replacement: step 13, image 2 of 2
      • Cut two, half-inch tall vertical slits into the front flap of the new cover. Center them with one inch between each slit.
      Ask FixBot
    14. Soft Leather Journal Cover Replacement: step 14, image 1 of 3 Soft Leather Journal Cover Replacement: step 14, image 2 of 3 Soft Leather Journal Cover Replacement: step 14, image 3 of 3
      • Thread the string closure through the slits so that the ends sit on top of the cover flap.
      • Pull until two inches remain on the left side.
      • Gently tie the journal closed.
      Ask FixBot
    15. Soft Leather Journal Cover Replacement: step 15, image 1 of 1
      • Congratulations! Your new journal is ready to use.
      Ask FixBot
Finish Line
Willow Tinsman
241 Reputation
1 Guide authored
UC Davis, Team 2-1, Andersen Winter 2025 Member of UC Davis, Team 2-1, Andersen Winter 2025
UCD-ANDERSEN-W25S2G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 101
All Time: 833
